stereokillah said:
respect for your work , where did you take pictures? in picture's studio?
there a lot a trimmer more than 10 what about it please?
HA! In my dining room with a piece of white paper and a wife that does graphic arts lol. Thanks for the compliment though ;D
Pots, yes alot of em haha.
All but 3 are optional. You don't have to put them, but I wanted to give the ability to fine tune the critical areas that people are always having to jerry rig a pot onto. And all but 3 places the less precise single turn will work fine. I used mostly multiturn because for prototype I need to be able to really fine tune. The pots are for:
QTY 2 - THD Trim
QTY 2 - Unity Gain (Or install a single 27K and forget it)
QTY 4 - Fine tuning L/R/In/Out Bargraph channels. If you tweak your unity gain, then you'll deinfiately want to use these for your outputs at least. If you use set values and use a fixed resistor for unity gain your bargraph tolerance will be within +/- .3db or so. There's really no way around this. Alot of resistors between your input and output.
QTY 1 - Overall Bargraph Vref Level.
QTY 2 - Adjustable Regulators. Here a more precise multiturn would probably be a good idea. Or you can just insert a fixed resistor and forget it.
QTY 1 - Ratio Calibration
QTY 1 - Meter Calibration
QTY 6 - HPF/T1/T2 Calibration like on SSC boards.
Hope that helps.
