micaddict
LOL
Phrazemaster said:I have a question regarding the Hammond Euro xformer. I am setting up my PSU for dual voltage, with a voltage selector switch. I'm fine with the primary winding, using a voltage selector switch that handles the series or parallel configurations for the primary winding.
I'm a little confused about the secondary, however. Which output do we use for 20V for USA, and which output to use for European use to get the 20V? Dan's PSU schematic shows 20V and the Hammond Datasheet shows a 10V center tap and two 5V windings...sorry if this is basic.
Also, will I need another voltage selector switch to handle the secondary?
I want to be able to take this PSU to Europe as I'm moving to England in a few months, and I want the dual-voltage capability.
Thank-you,
Mike
Phrazemaster said:Thank-you Dan, I suspected as much.
The same thing applies to the toroid transformer as well then, right?
Thank-you much..
Mike
The secondary winding can also be wired in series or in parallel. If I understand correctly, I should wire it parallel regardless of how I wire the primary to get 115v output..
Le Roux said:Hi Dan,
I wish to make the B version.
I notice that you bridge a lot of components, even though there is a hole in the PCB.
For the B version, I should completely follow the build pics on the first page?
Neil
stelin said:Hi Dan,
I'm building the M49c version and I have a (beginners) question:
There is an connection 8, "calibration input" on the mic pcb. There is no "calibration output" on the psu pcb. What is the calibration input for and what am I supposed to do with it? What have I missed?
Stefan
stelin said:Thank you, Dan.
One more question: I would like to inject a test signal into the mic board (not using a capsule) for adjusting the bias and see if there is any gain difference between different tubes.
I'm building a small faradays cage where I can burn in and test my tubes without having to solder them to the board.
Can I just connect the signal generator directly to FGRID and HG? Does it matter that the test signal is a low impedance source?
I appreciate your help!
- Stefan
