kmozart said:H+ with no mic is 20.89v
poctop said:kmozart said:H+ with no mic is 20.89v
then Something is Pulling too much current ,
I suggest then you install a load resistor between pin 4 and ground to rule out the psu ,
somthing like 47 ohm 1 W , you can stick it between pin 4 and gnd right in the xlr connector on the psu ,
this will load it at about 150ma for 6.3V , then you will be able to rule out the mic or psu ,
Dan,
kmozart said:poctop said:kmozart said:H+ with no mic is 20.89v
Dan,
Thanks Dan. With No mic, How much voltage should I have at H+?
Is there something else wrong? Pot Wired wrong?
poctop said:[q
you should be able to adjust the pot for 6.3V at 150ma with no mic connected and the dummy load installed,
if not then PSU got somthing wrong ,
Dan,
kmozart said:poctop said:[q
Dan,
and this is with the dummy load resistor installed ?,
dan,
These are the voltages following the schematic:
- After the diodes at C13 - 29.36V
- after R2 - 28.99v
- X1-2 - 28.86v
- X1-1 - 28.57v
- after R6 - 27.93v
-after R11 - 27.27v
- the lowest I can go with the POT is 19.78v
Could not find any leaky cap in the path, all the negative side of them has no voltage
kmozart said:I had wired the board 1 to 7 with the connector 1-7 corresponding.
Then the cable is wired 1 thru 7 on the corresponding one on the other side. Applied the load on the female side of the cable pins 4 and 7, with the male connected to the Powersupply, and I was able to adjust to 6.3V.
I have wired the male binder to the microphone board 1 thru 7 with reversing pins 3 and 7. connector pin 3 is wired to the board 7 and connector 7 is wired with the board 3. Also I do not have any capsule on the board if that matters.
Is that ok?
poctop said:kmozart said:I had wired the board 1 to 7 with the connector 1-7 corresponding.
Is that ok?
The capsule doesnt matter , if you have reversed pin 3 and 7 note that on the psu pin 3 is a sheild lift not a ground so the circuit ground should go on pin 7 , but on the mic boar it says 3 this one is reversed , hence make sure you have installed the jumper labeled SHLF on the psu board , i have made a excel spreadsheet in this thread to mention this ,
a couple of pages back , Let me know if you have installed the jumper SHLF specially if you have inverted it ,
DAn,
kmozart said:poctop said:kmozart said:I had wired the board 1 to 7 with the connector 1-7 corresponding.
Is that ok?
DAn,
I have the jumper, yes.
After re-checking the mic cable (Gotham GAC-7 Tube) and the Binder connectors, and make sure everything is tight, I put the things back together, and all of the sudden I got right voltages;
PowerSupply:
H+ is 6.04v
B= is 116.0v
Mic:
K is 6.08v ?!?! ( You have it at 1.6v couple of pages back in your picture)
A is 51.8v
H= is 6.03v
on 5 on the board I got 115.8v
Beside the K voltage, I guess I'm good?
I CAN SEE My Tube GLOW !!!
kmozart said:Seems like the H= and K are having the same voltage now.
When I measure between HG and the K or HG and H= it is 6.20V
If I measure between Fgrid and H= and Fgrid and K it is 0.93v
Winetree said:Just checking to make sure.
When using the remote pattern switching from the power supply, these two points are connected?
yes they are connected this is a cardiod only switch when off.
Is there a diagram for wiring the 7 pin XLR on the mic to the mic's round P.S.B.s?
