micaddict said:Yes, poctop's M49b with Peluso capsule (later killed in an accident) and AMI T49 tranny, sounded absolutely gorgeous.
Which Peluso capsule was it, CEK-47 or P-K47, I just noticed there are two different ones...
kmozart said:micaddict said:Yes, poctop's M49b with Peluso capsule (later killed in an accident) and AMI T49 tranny, sounded absolutely gorgeous.
kmozart said:On the input of my triad VP-T230-110 I'm applying 120 (that what my main is) and on the out I'm getting 136AC. Is that normal?
Im tying up on the in Blue and Violet then Gray and Brown, and on the out red-yellow and black-orange. That should be good right?
When I hook that up to the AC in of the board, with no load, just testing the power supply, I'm getting this:
B+ the lowest I can adjust with the R8 trimmer is 129.4DC
H+ the lowest I can go with the pot is 20.15DC
Polarization I can get 129.1DC for 8
64.5DC for Cardioid
0DC for omni
Is there a problem? if it is, Where should I look into?
kmozart said:Another Newbie question; Do you cut the pins/leads 8 and 4 off the tube? (5840)?
Not Clear on the pictures,...
kmozart said:Hello Everybody,
Do you know any good source for the round bodies? Just like the original ones? Like Poctop's prototype? Where I can use it with Yokemount and Binder series 691 - 7 pin connector?
kmozart said:Ok I got all together but the body and capsule. Still debating myself about what capsule to use.
This is the problem I have. I think my voltages are off, when I connect all together, this is what I got:
Any Idea What got wrong?
kmozart said:Thanks Dan!
Voltages on the Mic:
K= 1.612V - Pic 1
A = 122.4v - Pic 2
H+ = 1.623 - Pic 3
Pin 5 = 123.8v - Pic 4
#4 power supply = 1.683v - Pic 5
#6 Power Supply - 059.7 - Pic 6
#5 Power Supply - 123.7v - Pic 7
I can control A Voltage on the mic with R8, but that is the lowest it goes.
I can control K on the mic and #4 on Power Supply with the Pot.
This is the tube I use:
Power Supply ( Used the box before for something else,>..)
poctop said:Have A Look at this ,
Connect pin 5 and 8 to PSU PCB. ( Valid For North America )
Dan,
poctop said:ok disconnect the mic immediately,
the problem is the heater voltage you have no emission hence no plate current that is why the Anode voltage is so high,
i think you have issue with the wiring of the 20 VAC traffo ,
how did you configure it ,
show me how it is wired or draw a little somthing ,
only this part is suspect.
Best ,
Dan,
kmozart said:poctop said:ok disconnect the mic immediately,
Best ,
Dan,
Any other idea?
Thanks Dan for helping!
