Tedrummerx
Member
- Joined
- Aug 6, 2009
- Messages
- 17
Hey Dan, was there a specific switch you had in mind for the pad when you added that option on the pcb?
Tedrummerx said:Hey Dan, was there a specific switch you had in mind for the pad when you added that option on the pcb?
Scrappersa said:Did anybody try fitting it into the MXL 550 type body? Or any other MXL body for that matter?
mukole said:Thanks for that Dan,
I'll give it a go this evening,
I'm also curious though, there are 8 pins on the transformer, are only the outer pins used? or are the inner pins paired with the outer pins?
I notice there is windings attached to all of them, this is what was confusing me.
Thanks again,,
Mick
mukole said:OK, so if i bridge the inner pins of C and D i get a DC reading of 650ohm across the outer pins of A and B
and if I bridge the inner pins of A and B i get a DC reading of about 15 ohm across the outer pins of C and D
Is this useful? The other combinations wouldn't make sense because that would make it 1:1
poctop said:mukole said:OK, so if i bridge the inner pins of C and D i get a DC reading of 650ohm across the outer pins of A and B
Yes you got it , My original was reading about 717ohm and 15ohm IIRC
dan,
mukole said:mukole said:OK, so if i bridge the inner pins of C and D i get a DC reading of 650ohm across the outer pins of A and B
OK, you lost me a little on that drawing,
I tried bridging the centre pins A-B and C-D, using the outer pins put 1 volt AC at 1000hz into A and B and got 0.132 out of C and D,
in reverse this was about 7.6 volts, I'm not sure if this is right, Its supposed to be 10:1 isn't it?
Maybe there's some loss?
mukole said:Thanks for you help Dan, I've emailed Oliver
Mick![]()
poctop said:Are you sampling Mark's transformer (the Samar audio)?
It is on my wish list , Actually I have asked Mark to supply some info in the thread ,
Keep ya posted,
poctop said:mukole said:mukole said:OK, so if i bridge the inner pins of C and D i get a DC reading of 650ohm across the outer pins of A and B
I would not actually see another way in regards to this drawing here but 8:1 would make the more sense to me , make sure to ask oliver about the ratio.
DAn,
