bernbrue
Hi,poctop said:ISK Tm-66 ?
dimension Still unknown ?
Dan,
it seems to be the same as the T-Bone SCT-700. It measures 59 x 180 mm
regards
Bernd
Dan,
poctop said:I beleive the MXL is 47mm outer that should leave enough room for the 44mm PCB but this will be part of the experiment on MXL body type For sure.
DAn,
MatthisD said:poctop said:I beleive the MXL is 47mm outer that should leave enough room for the 44mm PCB but this will be part of the experiment on MXL body type For sure.
DAn,
The se2200a body is the same diameter. The PCB mounting holes are only 29.5mm apart. I think the 44mm PCB would have to be trimmed down by a couple of mm on each side unless you can mount the PCB right on the centre diameter some how.
Matt
