Banzai said:Did you attach the shield of the multi-wire cable between XLR7 and XLR3 to ground? Hard to see from your pic.
Yes. I'm following the wiring chart so the short run of cable inside the PSU has the black wire connected to pin 3 of the XLR7 (which after the connector now carries the shield signal from the long cable) and is soldered directly to pin 1 of the XLR3 connector.
Banzai said:Also just in case, double-check the XLR7 and XLR3 connectors themselves to see if they're properly grounded (worth re-checking all metal to metal contacts are good). Then see if you get a constant ground from the XL3 casing to the GND pin on the IEC, and same to the headbasket of the mic etc.
All continuity checks out fine.
