useme2305
1x http://www.banzaimusic.com/Salecom-SKS08LP-Subminiature.html
2x http://www.banzaimusic.com/Salecom-SKS06LP-Subminiature.html
useme2305 said:1x http://www.banzaimusic.com/Salecom-SKS08LP-Subminiature.html
Yes that is possible.Lakewood said:Another question: isnt it better to take a pair of metalfilm resistors with 0.1% tolerance for the matching?
Carnesd said:Your multimeter fuse is blown. If the leads on the jfet touch it's enough current to pop the fuse in your meter.
granger.frederic said:asymmetrical waveform is abnormal
possible solutions , most to lesser probable :
-bad biasing or bad Jfet , check biasing with a scope and signal injection
-bad source capacitor c8, change it
-bad capsule , try with another or a 80pf capacitor with signal injection, clean it , change it or look foward
-bad polarization resistor(s) check all voltages with a static voltmeter , clean or change it
-leaking or bad negative feedback capacitors c3 , c5 , c6 or c9 or even c1 , c2 , change it
-bad c7 , check dc after with signal sinus injection , change it
-bad c6, c7 ,L1 , L2 change or remove
-bad output transformer
regards
