signalflow said:Has anyone used ChuckD's U67/87 bodies for this build? How well did the PCB's mount inside/ did you have to do some trickery to mount them? I ask because I like the look of the larger body compared to the standard choices.
-Casey
wave said:signalflow said:Has anyone used ChuckD's U67/87 bodies for this build? How well did the PCB's mount inside/ did you have to do some trickery to mount them? I ask because I like the look of the larger body compared to the standard choices.
-Casey
The current PCB set for this build wasn't designed for Chuck's bodies. Dany had posted another revision that would work in the body but they haven't been manufactured yet. I'm sure you could get it to work tho.
Dave
kevinkace said:Started the build last night!
Can someone brief me on the original vs option in the BOM?
Tried search to no avail.
wave said:kevinkace said:Started the build last night!
What do you mean?
Dave
signalflow said:wave said:signalflow said:Has anyone used ChuckD's U67/87 bodies for this build? How well did the PCB's mount inside/ did you have to do some trickery to mount them? I ask because I like the look of the larger body compared to the standard choices.
-Casey
Dave
I've seen the revision 87PCB but can't justify replacing the ones I have already. I was just wondering if anyone has been successful in using this body. I'm already planning on the U67 so if I can't use the body with the 87 I'll at least have it for the 67 when the time comes.
Still, if there are any success stories I'd like to know.
-Casey
kevinkace said:wave said:kevinkace said:Started the build last night!
What do you mean?
Dave
The part difference IIRC is either pulse film or polystyrene caps. You can get the pulse films from Mouser but you'll have to get most of the styrenes from justradios. The styrenes have a more vintage kind of vibe but are sensitive to too much heat. I've already replaced 3 of them in my first build and I think another has gone bad. the films are more reliable but have a kind of sterile sound (this is just my opinion and it's very subjective). We have discussed this at length and people have built their mics with the films and mica caps with the CM2480 and have great sounding mics (tskguy is one of them)
Dave
C10, C8, C7, C1, C4, C6 all have 2 parts listed, original and option (in the XLS linked post 1).
0dbfs said:Hi, I just built four of these with AMI T13's and Peluso pk87i's. Thanks Dany, These are great tools to have in the kit. I'll be into ordering some more u1621 PCB's from you so I can make a test-jig to easily measure the fet's in circuit. I also plan to use the pcb's as a convenient way to set up a handful of other doner mic's I've got as single diaphragm circuit upgrades for the stock capsules.
Anyway, I've got an issue with my pattern switching on all four mic's. I have not troubleshot too much yet and was hoping someone ran across this already. In Fig-8, the back-side sounds pretty muffled... Omni, it's extremely filtered sounding... Cardioid sounds good.
My rear-backplate connection on the pk87i's is via the saddle screw and does have continuity with that side of the backplate. One thing I noticed is that the capsules came stock with the front-backplate connection via a screw on the teflon housing... That wire/screw does-not have continuity with the front-backplate-side of the backplate... The screws on the rear capsule teflon housing do have continuity with the rear-backplate but one or two of them do not.
Anyone else use the pk87i's? How did you connect up your backplates? Was it shipped pre-connected for the front-backplate and did you leave that one or change to the saddle-area-connections?
I did see the drawing earlier in the thread for the rk87.
jonathan
Matador said:I made a few changes to the BOM: I subbed in my favorite Nichicon UVZ electrolytic caps where appropriate (they are rater to 105C), and replaced all of the resistors with the Vishay RN55D series of epoxy coated precision 1% resistors. I went with the Styrene caps and mica's along with Dany's recommended Wima's.
sylvainmoreau said:hi poctop do you have any idea if you will have more pcb soon ?
