canidoit said:Do you have an estimate on how much it would cost to build a complete single unit, just checking on my budget.
kepeb said:so does the dc-dc converter just comprise of these?:
Mfr. #: AGQ26024
Manufacturer: Panasonic
Desc.: General Purpose / Industrial Relays 2 Form C High Sense Coil Voltage 24
so i can remove that from the cart if i intend to run from 24v? :-\
kepeb said:hmm, all i can see by TDK is
Multilayer Ceramic Capacitors (MLCC) - Leaded 1.0uF 50V X7R 10%
i was looking for something in the region of £12 as onlymeeee suggested to canidoit to omit from the build if using 51x PS
does the dc-dc section comprise solely of these caps then?
thankyou very much kato
kato said:Kepeb, that's a relay. The converter is the TDK product.
EDIT: wow, that mouser import tool is F*cking cool. That feature used to be so buggy.
Just in the past couple weeks I've put my EQN part list into one, the Airband compressor into a list, etc. And you can create a public link to them. For example, if it works like I think it should: THIS LINK should take you straight to the parts. (Somebody let me know if it doen't - or if you have to be logged in to mouser to see it.)
funkymonksf said:Hey david,
I was curious about the first pre you did with the Carbon Comps... I noticed this bom uses metal film through out. Any reason for going to metal film? And what carbon comps did you use in the first picture? I was also curious if you had a regular bom with destination numbers and part value for those who would rather go through another vendor? Regardless the last set off pictures got me real excited.
One more thing. What size or part number should we refer to when we order the grey knob from neve?
Brice
onlymeeee said:Also the only other thing to buy is the DC-DC converter for those running off +-16V (not needed if you're using +-24V rails)
This can be bought from digikey 445-2492-ND
I originally wondered the same thing as they are used for PP's EQN build. Check out the datasheet and you will see it is the correct part.Neil said:...I just wanted to double-check this part #, because the data box says the input is 24 VDC and the output is +-12 to +-15 VDC. Isn't that backwards?
jsteiger said:I originally wondered the same thing as they are used for PP's EQN build. Check out the datasheet and you will see it is the correct part.
Cheers, Jeff
