BC184L will have a different pin out, so unless confident at leg crossing etc.. I'd avoid.
Bit of pain that mouser have run out really. They've always had loads in stock.
Digikey have them in stock (for those getting the DC-DC converter from there anyway.)
Otherwise, local ebays?
OR.. if you aren't too bothered about 'authenticity' and want to experiment with some alternatives, (or even as a temporary measure (they'll all be socketed anyway, so easy to exchange) there's a whole heap of different transistors you could use.. BC107, BC109, MPSA18 etc..etc.. (obviously, will have to check the pins)
The DC-DC converter is fully isolated, so it uses the full 32V that a lunchbox can supply (not 16V)
For schematic, the part designations are the same as a 1073 schematic. So you could use that .. or I'm finishing up a version too.. (If there's discrepencies between the AMS site's, just ask, as this schematic's a work in progress, so to speak)
NV73schematic
(PS. The PCB has part designations and part values)
