Neil
Ok, I'll whack it out of there just to be safe, no biggie, in case I go to 51x one day. Thanks!
Onlymee, have you got a pic of what you mean?onlymeeee said:Well either really! I use it as a handy place to put the fuse instead.
canidoit said:Onlymee, have you got a pic of what you mean?onlymeeee said:Well either really! I use it as a handy place to put the fuse instead.
So you can apply the fuse to the board for people using the API lunch bunch - 16 volts?
onlymeeee said:So for +-16V operation I use the 2 fuses. It's the first component inline with the incoming +16V rail and first component inline with the incoming -16V rail.
Like so...
For 24V operation I put a fuse, instead of the long jumper. Also, you can leave out a few parts that I'm not I mentioned, no worries if they're put in. They won't do anything.
(also no biggy, but for 24V operation you can leave out the 4 components at bottom right of main PCB as they just affect the -16V (F2, fltL2, fltC1 and fltC3) If they're left in they won't cause any issues at all. They won't do anything, that's all.
onlymeeee said:For +-16V operation in an API lunchbox? Instead of fuse? Sure.
It's just a break between the incoming 16V rail and the NV73 circuit
kepeb said:also, why is there a hole in the metal under the gain switch?
canidoit said:Just curious how hard would it be to put a DI in there and if there is any space?
canidoit said:Regarding the unit. If you put the gain knob at 0, that means it will accept line level? Is that correct?
I read somewhere that the neve 1073 has 80db of gain. So these units have 15db of gain from level 0 cause your gain numbering only go to 65 and the trim pot goes to 0?
Wasn't there any switches available that will give you the 80db that Neve has?onlymeeee said:If you compare the schematic from mine to AMS site's schematic...
It's not circuit changes.
It's a mechanical restriction due to not having more positions on the switch.
For example, if you have an original 1073 on 65dB setting.. it has the same circuitry as mine at 65dB.
If you want 80dB instead of 65dB, (which having used many original Neve's and many ribbon mics, have never personally needed) then it's pretty easy to mod...
This will give you an extra 10dB at highest setting...
Add a wire like so (black wire top right)
http://www.thedonclassics.com/bottompcbMODfor75dBgain.jpg
(that'll get you to 75dB) Check for oscillation...
If all's well and you need the extra 5dB on the highest setting, then I'd jumper over 3.9k (R20) (and then make up the difference in the pad 'string' so the other switches don't change) so I'd change R21 to 7.2k.
That.. (as I'm looking at it late at night) seems the way.
But have a look at both schematics... either way is exactly the same as Neve did it. It's just which positions on the switch do you want.
