jplebre said:That way around, the only thing I can think of is that you have intermittent issues (eg. cold joints, bad wiring, socket issues) or a wrong sized cap.
You say the problem does also occur if there's a pause long enough, so...
sorry not much more info to think about anything more specific.
Have you done the suggested shunt on the attack?
jplebre said:Quick one - anyone experiencing flickering LED's with the unit on bypass (bar mode)?
I had this all along but I thought it was my previous supply which was struggling to keep up the power for all the modules.
I've just built a super duper power supply and the problem is still there. I'd say the meters go off 1 LED at a time at about 2min interval and then stabilise with 4 LEd's off, the last one flickering.
I'm thinking cap, but might be wrong? bad chip?
Rob Flinn said:What values are people using for RM1 & RM2 ? I only seem to be able to light 1 led in comp mode but all of them in bypass, I'm thinking the issue may be these resistor values.
