my 2 cents: hum is not only problem in Gyraf layout.
7824 is hot, and it is placed near gain reduction meter FET,
causing wrong meter reading after unit heats..
Also, this layout isn't best due to contami(ughthisenglish!)nation's
reasons-all hi-impedance pathes must be short and close to FET,
detector and att/rel.... or don't run some of 'em on PCB, using in very hi-z points wiring "in air" instead
(old Japan school learned from some cool Sur+ items
After building one 1176 from Gyraf layout, and freakin' with grounds
and other issues, I did mine layout and feel happy.
http://www.geocities.com/igor_jazz/1176pcb.html
Also, q bias and meter 0 moved to att/rel/ratio sw. board,
and added two relays for true bypass. Why 2?
You can use one relay and leave input trafo allways loading
output of your unit connected to '1176, but it is **ey style uggly trick ;-)))
(you know, one tub comp
Power supply is external.
(btw, I asked people in TT times year ago if they checked wrong grounds in Gyraf Layout or it was only my bad work
:grin:
Igor.
