"rotation"
You shall connect the OEP A262A3E in paralell both on primary and secondary to get 150 ohm to 6,25 kohm, and use it backwards to get a ratio of 6.45:1.
pin connecting as following:
use as primary, feed from the DI electronic
5+6 as high
7+8 as low
use as secondary, output to the XLR connector
1+2 as high
3+4 as low
Transformer core ground is pin 9
BTW, I find one of my earlier posting, about this OEP transformer.
Prodigy pro lab, 2004-07-08
Kubi,
The OEP's A262A3E connected in 6,25K to 150 ohm will fit in this circuit but I have not use this transformer in DI application when I have don a recording session so I can not tell about the sound quality.
I have only use this transformar for PA and communication applications and it is a good general purpose transformer for this very low price (under £10 in UK) and easy to get.
But the Lundahl LL-1538 (aprox. £40 in UK) is a transformer in a high quality division, and it can not be comparable with the OEP that is a semi-pro transformer.
A good middle alternative are the transformer that I use in my orginal version around 1975 the Sowter 3678 in 1:5 configuration (under £30 in UK)
Or maybe try the old famous Neve microphone input transformer
10468 / VT-22670 / T-1454, configurated in 300 ohm to 4,8 K
To day manufacture by Carnhill, type: VTB-9045
or Sowter type: 9145
--Bo
