seavote
the correct values for the j version are the same as gyrafs version. the easiest way to check the values would be to use gyrafs component layout
http://www.gyraf.dk/gy_pd/1176/1176.pdf
see pg 2. there are some components that are not used if using the lundahl input or out put transformer(check on the mnats board its noted there) im not sure which one i dont have the board in front of me.
