I think there is a fundamental flaw in you heater circuit. The dc heaters have one side connected to ground but the tubes fed with ac heaters are floating. However, you cannot float heaters, they have to have a path to 0V so the dc voltage between heater and cathode is controlled. Unfortunately you cannot just connect one side of the ac heaters to 0V as this will short out one of th diodes in the bridge. The only safe way to provide a single 0V connection to all the heaters is from a centre tap on the neater winding. Check out The Valve Wizard's page on this topic:
http://www.valvewizard.co.uk/heater.html
The section on dc heaters is towards the bottom.
