Tim Campbell
I got around to looking at some old broken capsules I've had for a while. One turned out to be very interesting. It came from a Superlux large diaphram microphone.
It's an exact copy of a U87 capsule. All the dimension's are the same, all the spacers are metal and the diaphrams are glued to the retaining rings.
The preamp is also a very good U87 copy.
I remember hearing one a long time ago and thinking it sounded decent.
The only two things I could really fault the mic on were that the backplate seems a little too highly polished (could use a good sandblasting) and that the passageway between the capsule area and the main body seems too open. I'd worry that sounds ringing in the body might be picked up by the capsule.
