I am very hesitant about using the cheapo switches for the gain make-up. This switch is effectively in the audio path.
Are there any alternatives?
Grayhill have same pinout switches, don't know exact cat. nr.
(edit: checked, this is C&K, not Greyhill)
There's goldplated Lorlins as well. I'll be in for 30-50 if someone
organise groupbuy for pcb version.
But, if you looking on schematic, RV1 trimpot affects audio
more than gain switch...
This way we can went in total audiofullery and...finnish the unit with
top MonsterCables 99,999999 puremonocristallic copper or something
like this. For me, it's OK, there was time when ESL63 at home
were connected with crazy good quality military silver-plated teflon cables
Which Transformer has the biggest impact on the total sound.
because i may want too make it switchable between a cheap OEP, and an other one. (possible of not??)
Depends on level you feed into compressor.
If 0dbfs=+18, i.e. very hot, input OEP will saturate very hard.
Interstage OEP cuts a bit lows and adds more phaseshift on highs than Marinair/Beclair.
IMHO, worthy to try ungaped (2567 iirc) version of lo1166
at output connected pri's in series, there's still enough headroom,
just re-calculate resistors values at gain switch and test. Will do this week.
I just asked a friend to wound me 1:2.5 trunnys on HI-B C-core
which I love for sound. This size bobbins are too big for my winding machine.
But hey, there's a lot of other substitutes, API output clone will fit,
Cinemag and Edcore have 1:2 outputs too.
Just...you know, as someone wrote there, mind is like parashute
