Official 33609 builder's tread. See 1st page for updates.
If there's 4-10 v on r44, something draws a lot of current. Just check everything.
Remove BA340 and check if anything else draws too much current.
Or, try to adjust trimpot on BA340 to max (CCV) position, maybe here is the prob.
so on R44 we are measuring between each side of the resistor to get approximatly 280MV. I am getting 153MV but not adjusting when I adjust trimpot on BA340. Trimpot is working and have adjusted fully.
I am measuring 16V from R44 to ground.
Problem is same with both boards. I am a little lost here so some help would be good.
Igor said:
hm...wait. Just check BA340 and all components across.
All componants appear to be correct transistors, capacitors diodes correct orientation. No bridges am measuring 12V at TP_D (24.3V from PSU).
C16,17,18 are 470uf. C23 is 1.5nf.
Any suggestions on further tests to weed out the problem. As it's happening on both boards I assume I have done something wrong.
Hello Guys
In post#16 Igor says that we should use cbe versions.
Its quite clear what is the proper pin layout in BA340 and also in the main board, I am having the same problem with r44 burning...
I´we replaced every bc214 and bc 184 with similar as a test, (bc560 and bc 183) without success. Both boards acting the same way on first power up...
I´m planning to replace every part except the resistors on ba340 to make sure everything is correct. If some of you have the order codes for ba340 from mouser etc I´d give you a BIG THANX, I´m getting tired :)
I think I recall some discussiong about some heatsink in ba340, but you who have finnished the unit didn´t use them. I´m just curious about the heat issues, and I´d also like to have your opinion about connecting the ba340 to main board, why could´n it be done with wires...
Cheers in advance,
Vito
CBE pinout printed on every transistor on PCB, except BC441.
Check BA340 point by point, maybe there's wrong resistor, reversed polarity diode,
or BC441 swaped with BC461. Check every transistor with multimeter on "diode" range.
This way you can know btw if the transistor's pinout correct (ebc or bce).
There's parts for using JE990 type opamp, with suffix "J". They printed on back side of PCB
and not installed with BA340.
Transistors from Farnell (sorry, Mouser is problem in Israel :)
http://il.farnell.com/fairchild-semiconductor/bc184c/transistor-npn-to-92/dp/1017657
http://il.farnell.com/fairchild-semiconductor/bc214/transistor-pnp-to-92/dp/1017665&crosssellid=1017665&crosssell=true&in_merch=true&
http://il.farnell.com/magnatec/bc441/transistor-npn-to-39/dp/1208596&crosssellid=1208596&crosssell=true&in_merch=true&
http://il.farnell.com/magnatec/bc461/transistor-pnp-to-39/dp/1208598
http://il.farnell.com/on-semiconductor/mje371g/transistor-pnp-to-225/dp/1459092
BA340 works fine on quescient current 6-15 mA without heatsinks.
Connecting BA340 with wires... Dunno. I suppose it will not oscillate with 50-60 mm wires, but why not
take the standard pins from IC socket and solder it to PCB.... Take IC socket and cutter, cut plastic...done.
Vito
You're right of course.  I just knew they had to be the right ones.
I built up a small test jig on strip board, with some pcb sockets to test the BA340 out of the main board.  This is useful since you don't keep frying the same resistor on the main board, which you then have to keep replacing & wind up damaging the tracks on the board.  Might be useful.
Nope. MJE371 located on motherboard.
These are  links to transistors used in 2254C available from Farnell.
Thanks guys!
Some improvement, R44 is ok and the voltage also.
CV+ is 3V, connected to link in main PCB
Relays are not working, so my unit is bypassed all the time. 12V link connected, and I get 24V when bypass is switched, but relays don´t click. Rhey work properly with external 12V...
Few questions, where is the link1 from bypass pcb going to be connected?
In main pcm com att1 and com att2?
Sorry guys, but Im stupid...
V
Vito Janeiro said:
Yes, 24v is connected from the psu board...
Check that it is getting to the relyas when you flick the switch.
Check that you also have the back emf diodes across the relays the right way round.
Make sure that if your running 12v relays that the 2 pads marked 12v near the relays are bridged.    If you are running 24v relays check that you have the 2 sets of pads marked 24v near the relays bridged.     If you have these bridged make sure you check the continuity with a meter.
Also if you remove the by_link-meter header you could try connecting your external power source to pins 1 & 2 of the header on the main pcb, which you can see run round to the relays & see if they click over.  I think pin1 should be positive.  If this works then you have a problem somewhere round the switch.
You could also connect your meter to the cable coming from the switch pcb to see if you have 24 there when you flick the bypass switch.
Really you should try to think about this logically, if you have a meter you should be able to work out where the power stops.
Like a few people here I have a Sifam AL19W but the VU type sold at canford. I am wondering id the SSLTech GSSL VU mod here
http://www.expataudio.com/expatshop/index.php?act=viewProd&productId=7
will enable my meter to work with this project
