tommypiper
promixe said:I have swapped most of the components in the limiter sidechain on one of the boards and it didn't get rid of the issue, so it must be something else. I'll try to arrange the shipping to Igor sometime next week. I am very very curious what his findings will be. =)
Thanks. Let's see if I understand. So, if it's the timing cap that can't recharge between LF cycles, then why were you swapping out components to see if that would solve the issue? And now why send boards to Igor? Were you suspecting something else? Or just trying prove that there are no errors in the build? Are you not sure it's the timing cap?
If it is the timing cap, there must be a way to correct it. (I know RuudNL has a circuit, but maybe other solutions too?)
Finally, how can this be a successful N*ve design with this problem inherently in its circuit?
One more question, would this not also be a problem in the 2254 series?
