BTW, did you manage a deal with AMS/Neve, for the implementation of your circuit? I'd be curious to see what magic trick you used. ;DRuudNL said:The first part of the sample is an original Neve 33609 with bypass on the compressor itself.
(Meaning that the signal is passing the electronics but the sidechain/control voltage is disabled.)
I'm serious.RuudNL said:
Can you achieve +4dBu? If yes, you don't really need to change anything.ilfungo said:Same problem with distortion at LF....
help please...
Two questions:
4.3. APPLY MAX. OUTPUT FROM SOUNDCARD TO INPUT, AT LEAST +10DBU,
LIM IN, ATT FAST, RECOVERY 50, LIM THRESHOLD TO +4, COMP OFF,
ADJUST RV4 TO +4 AT OUTPUT.
The max I can Archivate is +6 Dbu at the end of the trimmer
I must change the trimmer or some resistor value?
Indeed.RuudNL said:The distortion at low frequencies is caused by modulation of the control voltage.
Believe me, I'm very familiar with this.- You could avoid that the release sets in before a zero crossing.
- You could incorporate a short 'hold' time after a new peak. (Longer than the time of 1 period of the lowest frequency.)
- The word 'hysteresis' comes to mind...
nOK, I'll give it some thought. So I conclude the deal went good with AMS/Neve...?RuudNL said:Believe me, the solution is surprisingly simple!
It is only necessary to add a couple of cheap components. (To the compressor and the limiter section.)
But it reduces the LF distortion with a factor 10(!) at fast release settings.
(Unfortunately I can't tell much more, because I have a non disclosure agreement.)
