Built with ll1540, ll1528, APP992 opamp, and some '80s Jensen output transformer.
All the bc184, 214 changed to 550-560.
Very good sounding compressor with a noise level about -100-110 db at 0db.
It was difficult to calibrate, I had to change one resistor on the input to have correct values for the Lundahl.
For those who also have the meter problem while calibrating I have a solution:
I had a misunderstanding in Igor's calibration procedure.
After having the 3V from the calibration circuit I had to adjust the contol voltage trimmer to have -8db on the output.
After it I had to adjust the calibration voltage to have -20db on the output.
Adjust the meter trimmer to see 20db gain reduction.
And after it Igor says: go back to..... No, I shouldn't have to go back and repeat.
In the Neve calibration procedure there is no need to repeat loops.
In the first step you calibrated the control voltage and in the second the meter full scale reading, and that's it, go for the next step!
Maybe it will help to someone else, it was a huge amount of time getting to this result
