I just got back from a vacation and I will be trying to finish the PSU tonight or tomorrow. What value resistors do I need to use for the LEDs?
sahib said:3. You can power the LEDs as in the below picture. Apply ground to LEDs by using a black wire. Then power each LED by using a series resistor from its respective fuse immediately below.
Yes, those are the correct R values Dan. I'm not sure what LED's Cemal has supplied but I'm sure they will be fine.dandeurloo said:Ok, that is what I thought!
For the LEDs in Cemal's kit should I use these values to be on the safe side.
+48v use 4k7
+-24v use 2k2
+-16v use 1k5
I just want to make sure I got it right before I move on.
dandeurloo said:I was told by all the 51x guys to use 350's. I bought the kit from Ptown as well so I had to buy some 350's because Ptown wouldn't update the kit.
