kepeb
depending on where you are, jeff has posted a diagram denoting all the transformer outputs for those who have bought that toroidal in the US.
if you are in the UK there is a photograph posted somewhere that suggests the wiretaps exit the transformer in the same order they appear on the PSU inputs.
your chosen heatsink is too small to wick sufficient heat In my opinion, i would go bigger for the 16/24v rails although this is the right thread size and would fit the 48v regulator, the board mounted option is better tho.
jumpers:
if you actually using jumpers then the choice remains yours, if you dont like it change it. then change it back if you like. if i were to omit jumpers i would hardwire to ground unless you are confident you have good chassis connection from 511 to psu through your power cable.
jumpers:
