After a year collecting parts, I switched on the CRM tonight and listened to it clickity clack. Works great, as far as I can tell. For now I'm just using it to switch an input to one of two outputs, so level will mostly stay on zero. But level control works down to the vanishing point.
On the ohmmeter, the resistance between the input and output does not increase exactly stepwise as I reduce the level. Some steps are out of sequence. A couple of drops in level may sound greater than others, but it's hard to tell. It's not a problem for me.
Haven't played with the trim yet. One segment of one LED display is out (lower leg of the "4"). I found the hard-to-find parts through Newark. This project required a lot of thinking about the parts and much care during assembly, but it worked first time for me.
Now I need to get the talkback PCB and integrate that.
Cool project. Makes me want to do something with robots next...
Thanks, Igor!
Thanks, Igor!
