Nope, 2mm.Audioman said:@Moby
what kind of thickness you choose for the remote panel ? 3mm ??
jimkeaney said:Thanks for the reply audioman. I do not have a lab psu, but perhaps I can use my DMM to figure out the load? Would need some instructions on that though.
Also in the build docs for the CRM it states that all Molex connectors are:
1: +
2: ground
3: -
When I DMM audio output molex pins 1 & 3 there is continuity. Should the hot & cold be connected at the board?
Also can anyone tell me exactly how they have these boards grounded? I see 2 Aground pads. Chassis? anywhere else? Should the db25 connectors claws also be soldered? I feel like my issue has something to do with bad grounding or balanced/unbalanced issues.
thanks!
Audioman said:Hi Jimkeaney
you cannot measure the load of your unit with the multimeter in parallel you must measure it in series .
this is why i ask you if was possible power up the unit with a laboratory psu.
my unit is almost finished and i count to power up on saturday and i will make some measure
during the measures i make some picture and post here
yes claws are be soldered
P.S. i presume DMM mean Digital Multi Meter
1: +
2: ground
3: -
thanks!
jimkeaney said:I put VU meters in my CRM rack just to show where the program level is. But because I work mostly in the DAW (dbfs) I'm starting to think VU's were a bad idea. My convertors "zero" is +22 (SSL alphalink). The VU meters only have about 25db of 'range' as it is. I envy Janzoulou's meters (like 40db of range) post #428
Would it be silly to add a switch at the meters that adds an attenuator to the meter feed before it hits the VU amp? Or after? If I did this, I'd like to pad it accurately so I imagine some sort of trimpots would be necessary. Can anyone point me to a schematic or general ideas of what it would take to make this happen?
One big concern, will attenuating the meter feed effect the (resistance) anywhere else in the CRM?
If you put any resistance in parallel to your existing input impedance it will be changed of course. But, you can make cheap opamp hi Z input buffer and after that to trim signal for your VU's. That way the impedance change will be aceptable.jimkeaney said:One big concern, will attenuating the meter feed effect the (resistance) anywhere else in the CRM?
Moby said:If you put any resistance in parallel to your existing input impedance it will be changed of course. But, you can make cheap opamp hi Z input buffer and after that to trim signal for your VU's. That way the impedance change will be aceptable.jimkeaney said:One big concern, will attenuating the meter feed effect the (resistance) anywhere else in the CRM?
Right. Or you can do it passivelly but with possible impedance degradation. What's the input impedance of your amplifier ? Try to calculate parallel resistance of the amp and passive attenuation network and see is it drops below 10k. If yes, then is better to go with active buffer. Just my 0.2 cAudioman said:Hi Moby,
Your advice is make a meter buffer for attenuate the meter feed ??
You can probably make that with paralleling one more trim , but I can't see the schemo of the buffer. Is the trimmer gain of the amp or input pot? If it's gain, than adding one more trimm and making it switchable can do the job.I already have a buffer amp before the VU meters. This one from JLM http://www.jlmaudio.com/shop/index.php?_a=viewProd&productId=163
They come with 25-turn trimpots to calibrate the meters. Would I be able to take the signal after that trimpot and add a switch in the path with another trimpot to further pad it (-22)? or is this a messy idea? If ok, how could I add such a switch/circuit? Thanks for the ideas/help
Moby said:You can probably make that with paralleling one more trim , but I can't see the schemo of the buffer. Is the trimmer gain of the amp or input pot? If it's gain, than adding one more trimm and making it switchable can do the job.I already have a buffer amp before the VU meters. This one from JLM http://www.jlmaudio.com/shop/index.php?_a=viewProd&productId=163
Audioman said:Hi All
yesterday i power on for the first time my unit , without the box because at the moment is not ready
after trying 3 different vga cable i must solder a DIY vga cable because all three have a short inside on the pin 4 (as describe in the before pages of the thread )
after that the unit is working correctly and comparing to the mixing desk control room (tac scorpion) is absolutely amazing clean sound !!
it was like change my studio monitors !! absolute fantastic thanks to Igor for this amazing work !! he is an absolutely genius !!
now it's time to finish design the box of the remote control and the front panel
when i finish the unit i post some pictures
at the moment looks like this ;D ;D ;D ;D ;D ;D ;D ;D
jimkeaney said:Audioman said:Hi All
Congrats! Doesn't it feel great to see it come alive? I too had issues with pin 4 on the VGA. So I grabbed pin 4 with needlenose plyers and just pulled them out on each end. Problem solved
