Matador said:
I forgot to add, my output transformer is the Edcor XSM10K:600, which has a primary inductance of 40H. If my math is correct, the -3db point for low frequency response is about 9Hz with a 3.4K load on the secondary (f = (60K || Rp || Rp)/(2*PI*40)). Not too bad either!
You also have a 4.7uf & 1uF cap there to 'bump' somewhere ( ~ 11Hz?.)
Don't forget to figure in the effects of the NFB on lowering output impedance on the output stage. Even at at 3K I think you'll find the 10K:600 should sound pretty good.
That Edcor may naturally rise a bit on the upper octave. Some have reported this in other threads. I have heard it in some cases on the bench w/ or without a 600r terminating resistor. This may work out to be a good thing. Often times a 600r secondary can get fussy working into a higher Z load = fuzzy. Very easy to wire in a switch for termination if needed.
