shabtek
boards arrived, look nice
thanks JMan!
thanks JMan!
Awesome, I’ll double check the size and give them a whirl! Thanks guys!Those are MIL spec resistors...high quality! Check out the spec sheet linked below. I also like them because the values are actually printed on the body. The inexpensive 1% ones with the color stripes are usually difficult to read; "Is that a brown, red, or orange stripe? Which end of the resistor is the beginning when the value starts with 1/brown since the tolerance is also a brown stripe?" Yes...my eyeballs have excellent color acuity. It's the crummy paint used in manufacturing.
https://www.vishay.com/doc?31027
Bri
Noted. Yes, should be 22nF (.022uF). I will update the BOM this afternoon when I am at home. Thank you for that catch!Going through the posted Mouser BOM (only for the components I do not already have so not a complete list) and I have found a discrepancy.
The part listed for C3,7, & 23 is a .22uF, it should be .022uF. I found MKS2-.022/63/5t to work
