Check Nielsk's group buy thread in the Black Market, which is where information on that group buy is being shared.any update on the xformers and metal work? I do have the boards that look sweet. I'm out the loop. thanks
First and most importantly -- did you remember to contact Igor/UTM and request that they be custom wound for 600:600?The famous "one more" question: I bought the UTM3523LP, but it has a different wiring ?!?
It has Red/yellow/blue/green/orange/black but ordered it as custom, so i wonder if something is wrong here, or can be fixed ?
I originally asked Igor/UTM to have custom-wounds, but it seems it somehow got lost in context; you can PM me directly and provide infos, however mine (which is MAYBE the wrong ones, looks like this):First and most importantly -- did you remember to contact Igor/UTM and request that they be custom wound for 600:600?
If so, do not worry, it will be quite easy to wire up correctly. However, I want to wait until we know the answer to the first question before describing the solution, because if you bought the stock part by mistake and the wiring is any different (I'm wondering if the custom-wound one has the black and blue leads or not), I don't want to cause any confusion for other builders reading this.
EDIT: Just adding, the reason that the lead colors are different if you use the UTM is that I designed the project around a Cinemag transformer and the UTM was an option that was thought of by Herbert when he was helping me proof the boards. It's normal for different transformers from different manufacturers to have different lead colors -- as far as I'm aware, there is no standard for this (nor any reason to have one).
Thanks bud! It'll be quite a while before any photos of mine surface haha. I wasn't expecting to start on anything with these until I finish my last two in-progress rack projects, but I have more time than extra money right now and decided to see what I already have in stock for these so I could get the time consuming BOM and parts sourcing out of the way, then started messing with the drawings. Gonna stuff one pair with polystyrenes and Carnhills/Cinemag, the other pair with WIMA FKP or MKP (FKP until the size is an issue, then switch to MKP) and UTM, and maybe do something like red frequency select knob for the ones with WIMA and grey for the ones with polystyrenes, to differentiate the two in the rack. I'm already daydreaming about trying an Orange 86 > Reddish 500 > D-LA2A chain, using all my latest builds.I continue to admire your precision! Would love to see a drawing or some photos of the solution you described once you have them.
FWIW, this was a concern of mine as well initially, but I've built a couple units now and as long as you're mindful as you pull it all together, you can get everything to sit as accurately as any other piece of DIY or commercial gear I've used. However, the perfectionist in me is really excited to see what you do!
Here's the link https://utmindustry.com/utm3524/I may add that in my contact with Igor of UTM he said that they've had enough interest in the custom 3523LP 600:600 that they would add it to the webshop. Hasn't happened yet but he said he'd keep me posted
Hey, apologies! For some reason I wasn't getting notifications of your messages, but I just checked and I do indeed see the last two you sent. I'll respond to them!Hi Jordan, just posting here 'cause I think my PMs are not going through. Just wondering if you got my replies to your July 28th message. Thanks!
(sorry to hijack the thread)
Great! Sorry, really thought it was a website issue.Hey, apologies! For some reason I wasn't getting notifications of your messages, but I just checked and I do indeed see the last two you sent. I'll respond to them!
Question for the group: does anyone know how to reduce the size of a PDF without Acrobat? And what is the actual file size limit for the forum? I have the build guide ready to go, but it is too large to upload thanks to all of the pictures.
