That's likely to be the issue. I'll ask you to check two things.
First, check that you have positive voltage coming into the module in the first place (again, multimeter to read DC, black probe on 0vdc pad, this time put the red probe on the V+ pad on the card connector right above the black probe, again being very careful not to short them).
Assuming the positive rail is fine, we'll do a continuity test with your multimeter. Turn off power or unplug the module from your test jig. Set your meter to continuity mode, and measure between the op amp pin 8 and each of the other seven pins. If you socketed the chip, I'd remove it and just prove the socket. If you have continuity with another pin, it likely means there is a short.
If neither of those tests yield anything out of the ordinary, we'll keep hunting.
