Thanks again Thor ,
tons more good stuff there Im sure ,
Just doing a second readback of the other thread ,
to make sure I understand everything correctly ,
The idea of an isolator seems jamjared in peoples heads ,
This is a change to the way the grounding is arranged ,
techincially I guess you are isolating the supply , but thats different thing to isolating the data lines using opto 's .
There is extra inconvience using batteries ,
4 nicad cells goes to over 6V on charge , where supercaps are limited to 5.5v . with a fully charged battery on load it drops back to 5.4v .
Running time of the device is around 8-10 hours ,but of course that might vary depending on if the headphones are driven or not ,
What I had in mind was this ,
A battery based USB supply , if possible entirely passively filtered and unregulated ,
Then a quiet mains based charger/battery management system that takes a cue signal via midi to tell it recording(or playback)is underway , in which case the charger is shut down and disconnected at the mains side ,
If mains power for what ever reason goes down the battery seamlessly takes over without interuptions in the audio path ,
Maybe I just set the on charge voltage to never go above 5.5v , a trickle charge is the old term associated with nicads ,
the USB device would always be on load , permanently powered with a small trickle charge until playback is pressed .
Theres a few off the shelf charge controler pcbs on ebay with simple programable logic , they have a DVM and sense inputs that can be used to trigger end of charge cycle at a preset time or voltage level and dissconect the battery when it drops to preset a threshold value.
Same as yourself I realised the good in permanently powering the day to day listening system many years back , The Quad II's formed the heating system in my room in winters over the years ,
Not so much these days with the cost of electricity and tubes !
Thanks again for the info on modding the good old fashioned in line iron linear adapter as low noise powersupply , I see tons of these things in electronic recycling all the time , it easy to pull a few of the appropriate voltage when I drop off my empties down at the yard , even an non regulated DC adapter can easily have the 317 regulator added .
A 9v version of what you describe above with the supercaps sound like a great idea for use with stomp boxes ,
Nowadays the typical pedalboard has half a dozen SMPS ,each with its own unique whine/buzz and a grounding scheme like nest of vipers over back and through the pedal casings ,supply wires and signal cables , very much like the USB power problem , its a major cause of poor tone with guitarists in the modern day.
Noise gates to me are a poor way of tackling the problem ,
From a sound engineering perspective you often end up where the overall S/N ratio is determined by the noise comming off the guitarists rig and there isnt much you can do about it in a live situation .
In the studio environment the issue can be tackled at source , but its very much something you need do on a case by case basis , theres no short answer , the best grounding arrangement can be determined manually , with the help of your ears or software if you want to look .
I wonder how many people got tricked into buying fancy mains power filtering systems that cost thousands but dont end up making much difference to their buzz issue , where the proper local USB grounding/power arrangement would have cured it to a greater extent .
I'll have to keep my eye out for an Ifi Zen HP amp , like you pointed out , its easy to do better than the basic SMPS that it comes with ,
Amir over on Audio Science review did testing , results were generally very good but that the PSU running out of juice was fairly evident from the distortion readings , which someone pointed out to him ,
The other thought is a small USB interface might consume 2-3w ,
a 40Va transformer gives a very generous 10:1+ current margin , means the transformer runs nice and cool with less energy lost in the windings and core material ,as well as better handling of short term demands for current .
