[quote author="EEMO1"]finished my g9. works, but only 1 channel works. input tube on channel 1 (v1) doesn't heat up. can this be the problem? i think the socket may be badly soldered...
how do i discharge the unit? im scared to go back in there... any help is appreciated. how do i measure it's safe?
channel 2 works and the sound is good. no hum, distortion or anything. im happy about that.
thanks,
eero[/quote]
Eero,
No heater = no sound. This is most likely your problem. When probing to see if there is any charge stored up in your caps, clip the neutral lead of your meter to ground, and then probe for voltage with only one hand. It's safer that way, since you arent making a pathway from one hand to the other (through your heart). Tie your other hand behind your back if it helps. :wink:
It looks like all the HT caps can bleed to ground through the resistors around the TL783. The only one I'm not sure about is C14. I'm still learning though, so perhaps one of the electro-jedi masters can fill in the blanks.
Regards,
Chris
