I did a DOA shootout to confirm several things I had suspected. I used the Igor Sontec and a modified PRR176 compressor that has the same input stage, but with a decoupling cap instead of a servo.
My hunch was that the input de-balancing DOA stage is much more sensitive to opamp changes than the summing/output stage.
So I gathered all different types of DOA's I have and started testing.
gar2520, ppa APP2050, ppa APP2055 (FET input) and ppa's latest APP992. They all measure the absolute same frequency response just as expected. The differences can be seen with high resolution FFT distortion measurements as slightly different shaped distortion spread. The differences are very subtle. I had better success seeing what was happening with square waves and oscilloscope but those results were tainted due to RME sound card band-limiting artifacts.
I wish I had a better way of actually seeing what is happening, because especially when chaining channels where more than one opamp is changed, the difference is very easy to hear on transients especially. And yet the differences between distortion plots are very minimal.
gar2520 is smudgy and had obviously most distortion of all these, even midrange-harsh at times. I guess that's one of the reasons why people want to mix rock through API gear. APP2050 is very similar but more transparent, a good work horse I would say. APP2055 does something interesting to transients and imaging. There seems to be a bit more 2nd order distortion, but this sounds cleaner than APP2050. This is a sound I have not heard from FET input chip opamps. gar2520 sounds even "lofi" in comparison.
Then there's the APP992. This is highest mastering grade stuff. Best opamp I've heard, chip or DOA. It goes beyond the transients and imaging of the fet APP2055 and even adds some bass punch. It's also FET input, but seems just about everything has been improved compared to APP2055.
[edit]
Again, I wish I had some quantifiable method to *show* what is happening. I will get a signal generator one day and redo this test with proper square waves. Guess I should get some more exotic DOA's and see what they do as well. To be honest I did not expect differences this significant.
