duantro said:
How do you check for the ms adjustment? With an audio analyzer or a voltage measurement somewhere?
Feed signal to left channel; short right to ground (no signal);
ms is in; adjust the pot for minimum signal at right output.
ilfungo said:
Igor said:
0.2 db difference: not related to IJR DOA's. Trimmers are for minimization of DC offset.
Check all resistors in audio path on MS board.... also, did you tuned it for minimum crosstalk in MS by MSBAL pot (left bottom on MS/Bypass pcb)?
I went ahead in the test ...
if increase or decrease the input level of the difference in M / S changes from 0.2 to 0.1 in a strange manner, a higher level or lower = 0.2
mid-level = 0.1
If I change the frequency up to 3000 Hz = 0.1 from 4000 up difference = 0.2
I also tried to replace the IC but nothing changes.
Which resistors i must check?
Now I lost you
Most of folks were say "Welcome to analog world". Well, not much curious, but still interesting what is going on here
EQ is off on both channels; MSBAL pot adjusted for minimum signal leakage; feed 0db from analyser and measure output! Dats all! Should work fine.
About digging into details.
If you use soundcard for testing, take into acct, it should be calibrated with rms voltmeter.
Than, if you use handheld fluke as rms voltmeter, take into acct it shows bit different at different frequencies.
I used my oldy heavily modified Boonton 1120.
If the eq input is referred to 0db, outputs of the eq are within 0.1 db with or without ms independently of frequency.
I know Boonton gives me about -0.05 db at 20kHz vs 1kHz and have to find some time to adjust the variable cap at input card, but I know the unit's error...so fine with me.
Now, 0.02db is within the normal error of rms detector of Boonton at 1V RMS 1Khz which is really not bad.
Audio precision have almost same precision but have also a digital compensation, so, reading can be bit better.
If the eq will be used for mastering, you can order from me Uni-Q, digitally controlled, completely tested etc. - it will be available very soon.
For the DIY use, if you do mastering version, ahm... you do it on your rescue
If you build this EQ for mastering, 1% or better resistors should be used everywhere and no pots - switches only.
And I'd avoid cutting the boards like some folks did and running long cables to switches.
Stepped mastering unit should be done with this thought from the start.
If the eq is used with pots for mixing tracking etc, 0.1db difference between channels is fine, mixer's fader or gain knob have way more tolerance.
The tolerance of pots when eq engaged will add more unpresision and imperfection...but that's the way it goes
Well, just some OT thoughts
If you will explain me as for complete stupid what is going with your EQ and what is the test setup, I will try to be helpfull.
Measuring units should be in db's or volts but how can i understand what is 0.1 or 0.2?
