Ricardus
WILL SOLDER FOR FOOD
I have some boards and just need to build them!
That's good cause I just sold my 4 spare boards to JanalexI have some boards and just need to build one.
Thanks! Yes he did. Not sure if I really need it tho. It‘s also a bit to short, so I can’t use the 2 screwholes next to the card edge connector.Nice work! Did Frank do your bracket as well?
Will do! Do you maybe have a picture where to put the stop pins in the grayhills? Didn't do that yet so it rotates all the way through.Sounds like you've got something to start with. Try a known, calibrated line signal with peaks at or less than 0dBu, with pad engaged and gain set to 20, and let us know how you get on.
Yes I'll try it with a condenser - I didn't record any test yet because I assumed nothing got through.Do you have a condenser mic to try (or anything hotter than an SM58)? Leaving the input metering question aside, how does the recorded SM58 sound if you increase the clip gain to your normal levels - clean / distorted, any noise, etc?
Yes, I tested them tho and they seem to work (put through a 60 Hz sine wave that got affected by the HPF and the EQ did *something* to the signal atlthough I couldn't quite hear it in detail due to the fuzz.It's worth keeping the HPF and EQ section disengaged during all this initial testing by the way, to simplify things.
Here you go:Will do! Do you maybe have a picture where to put the stop pins in the grayhills? Didn't do that yet so it rotates all the way through.
Yes, should be the same for all 71 series Grayhills. I'd suggest testing with a bent paperclip or a sewing needle or something first, if you can. The datasheet for the switch series should help too.Is this the same for all 4 grayhills? Put in 0 and then have 6 for gain and 11 for High/Mid/Bass?
Thank you so far for your help! I still need to wrap my head around grayhill switches...^^
Thanks!! I’ll check that points again!there will be a drop at the output of the EQ cut switch since there is a loss as it is a passive eq - thats normal. so that means your problem is in the makeup / output amplifier somewhere. i'd double-triple check solder joints, resistor values, transistor orientation in the areas around Q5, Q6, Q7.
