oongbac
- Joined
- Apr 16, 2021
- Messages
- 76
That does reinforce the suggestion of an issue with the output amp. Are Q5-7 the right transistors, and the right way round? Worth checking the datasheets for your particular transistors to make sure the pinouts are as you'd expect.When I put a scope to emitter and base of Q5, it is okay. But at the connection of collector / r39 / r41, there's a distortion. Is this can be a clue?
Thank you very much for kind reply. I’ll check all your suggestions! I run my TRs to TR tester and pinouts are all good. Thanks again for share your insights!That does reinforce the suggestion of an issue with the output amp. Are Q5-7 the right transistors, and the right way round? Worth checking the datasheets for your particular transistors to make sure the pinouts are as you'd expect.
As Matt says, it's a relatively simple circuit with nice discrete sections (2128 amp > EQ > 2128 amp > buffer) so a systematic approach to checking each part in turn is the way to go. If I was in your shoes, my next step would be to run a calibrated test tone through the unit (say -4dBu 1kHz, gain set to +20, pad engaged, EQ disengaged) and then measure both AC and DC voltages at each pin of each transistor. Any differences in DC voltages between the two 2128 amps would be particularly instructive.
It's also worth checking, with the module unpowered, that you don't somehow have continuity between the ground of the EQ section and the V- in the output amp. I'd imagine that would lead to bigger issues than you're seeing here, but worth excluding any cap failures, solder bridges, or similar.
DC voltages on transistors in the output amp are lower than those in the preamp? Are the main power rail voltages the same between each amp?But every pins of TRs in output amp has lower DC voltage
Yes. They're both same. V+ is 15V, V- is -7.9.DC voltages on transistors in the output amp are lower than those in the preamp? Are the main power rail voltages the same between each amp?
Try removing R43, that should set it to unity gainCheck resistor on both 2128 with color code and DMM, they're identical. Is there something can cause my problem? And I did some crazy experiment that flip Q5. And then clean sign wave came out, after a minute it change to distorted signal. And Q6 of my unit tend to get hot when I apply sign wave.
Yes. R48 is 120R.Q6 gets hot? Can you confirm R48 is 120R?
I used signal generator and setting was 1kHz around 300mVAC.But what level signal?
