Package came late so just had 30 minutes to replace the regulator and move the diode and measure. My voltages are now prettt much exactly as oongbac. Don’t have time to listen but presumably problem is solved.
Use the caps. Might help won’t hurt. Look at the LM317 datasheet for reference.I will shoot a pic later. Just remove the diode and place it where the 7808 outside pins were. The 7908goes where the diode was. The pin closest to the connector needs to go to the grounded third contact. The middle pin slides right down into the hole and the last pin needs an extension as shown. I am still debating whether to use the caps as my datasheet for the Texas Instruments regulator doesn’t show any caps.
On the power supply question, I would use the POS48PSU from Silent Arts - or the FP48PSU if you want an additional utility rail for LEDs, relays or whatever. I've used a bunch of Volker's PSU boards over the year and they've all been rock solid.Secondly, is there a readily-available PSU (prefab or project) that would be a good choice to power 4 of these in a single 2RU box?
Excellent, they're looking great! Same for @fritzmyname. I'm very glad you were able to sort out the issues (even if we don't yet understand why it worked!).View attachment 119342
I used this knobs. I've got from domestic supplier. Not that super neat but size is good. I think I have to replace knobs for pots to smaller ones.
And I think design of front panel is really cool with the engraving. Thanks @TwentyTrees again to provide panel design. And also thanks @dogears to provide this great project and big help to solve problems. I think I should make more of this units.(Or buy IAA H9)
The revs were for the 500 series power. If you send it +24V it'll be fine.Hi folks,
After a full year of sitting on these PCBs, I think I'm finally going to dive in and start building. Two quick questions, I noticed there have been a few revisions made to the 500-series H9M version; it doesn't look like there have been any updates to the H9R (the version I'm building), but has anyone encountered any issues with the H9R as-is in the dropbox files?
