Thanksbruno2000 said:C7,C121
Bruno2000
drask said:Thanksbruno2000 said:C7,C121
Bruno2000
And in the case they're good?
Could it be VT26 or 25?
bruno2000 said:drask said:Thanksbruno2000 said:C7,C121
Bruno2000
Probably not. Burning out that resistor indicates a catastrophic short to agnd of the junction R67, R73, C7, C101 side of the resistor. Check for solder bridges.
Bruno2000
drask said:bruno2000 said:drask said:Thanksbruno2000 said:C7,C121
Bruno2000
Bruno2000
Problem SolvedThanks.
You were right. C7 was reversed
bruno2000 said:Ever wonder why the 40 Hz and 80 Hz settings on the HPF sounded the same? It's because C110 and C108 are swapped (mis-labeled) on the switch board, that's why.
Bruno200
1. There are two unlabeled parts one resistor and one capacitor near the power connectors. What are these values?
2. Do I populate R47 with a 82K resistor?
3. Values for AOT?
A.O.T. 8 = not used
A.O.T. 10 = 10R
aot1 = 330R
aot2 = not used
aot3 = 47k
aot4 = not used
aot5 = 3k
aot6 = not used
aot 7 = 3.3k
aot 9 = 68k
Where are the meters connected to the board via CV?
LORLIN Switches should they be shorting or non-shorting?
Switches
BYPASS is a SPDT ON-OFF-ON?
FAST/SLOW is a SPDT ON-ON?
LIN/COMP is a DPDT ON-ON?
LIN/THD is a DPDT ON-ON?
Thanks for the answers. A couple of more then I will be able to wire it up. I am using the LL1540 transformers and there is some suggestion to use 12K resistors for asymmetric input amplifier. Not sure if I understand this. Has anyone else use these transformers and can suggest wiring? Also would like to know the values used in CZ and RZ.
Bonsaimaster said:I am luck enough to get the Fester PSU board with the kit. I understand the connections from it to the motherboard. It has a couple of labels I don't understand if anyone can help.
G1
G2
G3
~G
~25
~1
I am using an Antek AS0528 with to 28V and not sure how to connect. .
