Nice Warpie, I'm waiting for thisHi drask. Unfortunately, I don't have any samples yet. I'm waiting for the last PCBs (Band1) and in the meantime I'm working on the enclosure/front panel. Once it's complete I will post some samples.
warpie said:...
Thanks abbey road d enfer. Unfortunately, I'm really struggling to find the cause of the heat problem so I might have to leave with it as I can't think of any other possible solution.Yes, the Zeners are regulators.
warpie said:Biasrocks, thank you for the info. I haven't built the limiter so it's good to know that this problem doesn't appear on the limiter. I will also try your suggestion about the current flow. Can you please explain me why I need a 10ohm resistor in series with the 2 Watter? Can I not just put my DMM in series straight after the 2Watt resistor?
Some time ago, I measured the current by inserting the DMM in series from the PSU +28V rail to the main board and it measured around 200mA.
You're right. I was measuring with reference the gnd. There's no DC when measuring between pins. There's no crackle but I was thinking that it might develop after a period of time.regarding 2: is there any crackle? If I get it right, then things will be fine when all 3 points are at the same dc level because then there is actually no dc across the pot. It would only be a problem if there was dc between these points, but measuring from 22 to 23 or 25 should show no dc. The voltage between the pot and gnd is irrelevant in terms of crackling in this case. So if I get things right there might be nothing to improve, getting rid of the voltage between the pot and gnd might even affect the transistor bias?
Sorry, I meant mV and not mA (I edited my post). Thanks for pointing it out. A 47K resistor improves the DC by 5-6mV so I now read around 50-55mV. What amount of DC is acceptable at the output and moreover, is there's any danger of damaging the output transformer?What are you measuring at the output, mA - not mV? Maybe just connect 47k from out to gnd and see what happens?
