thomasdf
I can access the website, it seems like it's back online. I hope Brian is fine. His site is crazy... I'll take to time to read it entirely... Lots of informations on it!
gyraf said:'tis one?
THANK YOU!Hope this helps:
The nominal frequency of shelf eq's is NOT the turnover ffequency of the associated filters. The listed frequency is where the max boost cut happens, so it's typically about 3 octaves above or below the 3dB point.Is anyone willing to help me understand the low shelf topology/function and how to calculate those frequencies? When I calculate them as LR filters, I'm getting way lower cutoff frequencies than are listed.
Thank you! Makes way more sense now.The nominal frequency of shelf eq's is NOT the turnover ffequency of the associated filters. The listed frequency is where the max boost cut happens, so it's typically about 3 octaves above or below the 3dB point.
If I gave you a Mathematica spreadsheet that accurately calculates them as s-domain laplace transforms would that help? The complication here is the inverting stage gain, which shifts the frequencies a little bit compared to a passive circuit.Is anyone willing to help me understand the low shelf topology/function and how to calculate those frequencies? When I calculate them as LR filters, I'm getting way lower cutoff frequencies than are listed.
