sr1200 said:
We should remember that FireWire was never really accepted on Windows at all. There were serious problems with FireWire on 2K and XP, as I remember. And very few desktop Windows boxes had FireWire built in and I can't think of any that had FireWire 800. I also can't think of any Windows laptops with FireWire.
Gonna have to disagree with this BIG time. Yes, at first firewire was almost taboo on a PC, but that changed (and quite rapidly).
Every laptop in my house except ONE has firewire (mini 400 port). And 2 of my shop PC's have firewire 800 ports via PCIe card and they all have onboard firewire 400 ports.
Then you're the exception, because none of the PC laptops my friends and co-workers own have FireWire, and only one Dell series seems to have FW 400 out of the hundred or so machines we have around the office.
Certainly, if you're looking for FW on a PC, you can find it, but it's not on most machines that I've seen. YMMV.
I think mac failed at their attempt to redesign the new "pro" and turned it into a hipster barista expensive toy. TB chassis are not acceptable solution for a "pro" machine. That's what you use when you run out of the slots that are IN the machine, or you're using an iMac or mac mini or laptop.
My guess is that Apple has a narrow definition of "pro," in that the professionals they're targeting are the video render guys.
Because if I was designing a computer to be used as a DAW, I wouldn't bother with all of the video/graphics hardware they put into the new Mac Pro. I wouldn't bother with the multiple HDMI outputs or whatever else.
All the DAW really needs is the ability to drive a couple of monitors at high res (3D rendering not necessary), a boatload of RAM so you don't need to hit the disks as often, and a couple of quad-core processors for the processing. Would eight cores suffice? The point is that the requirements are not as extreme as for 4k video rendering.
For your audio interfaces, a single Thunderbolt wire daisy chained through your devices should be sufficient. Of course, that's looking at the future, but I would be VERY surprised if MOTU and Apogee and Avid weren't already designing updates to their products which use a Thunderbolt to FireWire bridge chip in front of the DICE or whatever they use. That way they don't have to wait for or design a custom Thunderbolt device controller chip.
But, as JR says, I could be wrong.
-a
