Hi
today is a good day today
8)
My first impression after 15mn testing:
-I need more time to test it a his best
-Really take care with the Angry drive but i like it
-The bias is really subtle
LPF Subtle
The 2 switch Overdrive and Tr Pk are crazy in combination with drive
-Lm350 hot after 10 mn maybe need a cooler.
The only thing which i find a little bad is the effects really push up the output volume and it's really easy to go in the RED
Whatever it's a fantastic tool
I have an other set of pcb and i will do Bernd MOD pentode to triode to compare
I just rewire edcor output like input 1-2 output 7-8 this revomed a lot of noise.
I've got a hum when i boost to the MAXIMUM So i need to fix that .
Take care with the demo track especially at 2.55mn LoL
I attached a new and BETTER demo ( i turn all the pot and switch)
https://www.sendspace.com/file/wfwvqi
I will finish my other channel and test it on a stereo drums mix
A last thing
someone try to ground the psu to the stars ground to remove hum ?
Good luck
