Potato Cakes
Hello,
Going through Colin's guide for fixing up a TAC Scorpion PSU, it shows that a thermal insulating pad is added between the large heat sink and the PCB. I have been looking around for thermal pad, thermal insulating pad, thermal insulating sheet, etc., and I haven't been able to find something that is being used in the guide. I have found small thermal conducting pads for regulators and larger and expensive sheets that were also the same really thin material used for regulators, but no thermal insulating sheet big enough to be used for the PSU's heat sink. If someone knows what the thermal sheet used in the guide is called or has a part number/link to share, would you be as so kind as to reply with it here?
Paul
Paul
