Here are a few images.
I built mine with an internal (Meanwell caged 36V) PSU. To avoid interference I added extra shielding and placed it as far away from the main PCB as possible. That made assembly quite a bit more tedious. But it worked out great, SNR is better than advertised and clean white noise only. The chassis connection is made at the PSU and not through the meter board, but I didn't notice any detrimental effects.
The tubes are very microphonic, not sure if or how much that varies. I bought a bigger batch but so far only used four. Those were easily matched via the testing instructions almost down to the noise floor.
Sourcing was a quite tedious thanks to the current supply shortages. I will have to shorten the axis of a couple pots and get different knobs. I matched everything meticulously and can now get the channels to perform very, very closely.
The frontpanel layouts and the insert plate (all supplied by Frank from frontpanels.de) made mechanical assembly a breeze. I had to mount the sidechain boards at an angle tilted up so as to avoid them touching the two 47uf capacitors.
If anyone wanted to build a vari-mu compressor, this would be my recommendation. I have built others, but this is by far the easiest, best documented, best sounding and also the least expensive. And board are so well-spaced that even beginners won't have any problems creating solder connections accidentally.
If I could change one thing, I would prefer to have the gain after the compression as make-up gain.
PS: This is a desert island kind of unit. It doesn't colour the source sound and works great on everything.
