UA Apollo preamp knob
Really? Who did you have to blo... I mean bribe, to get that? They wouldn't even share the already-compiled* firmware for an 8pre...
* Compiled, as in NOT the source code, as in no IP infringement even possible, so no real reason not to.
I called
Your methods vary from mine I guess
Yes but Im not sure you'll find one.
At least not easily.
You might have to go with whatever is available and make it fit.
Other manufacturers will make similar pots that will also fit the PCB, so you could find these data sheets too and see how close you can get to the original.
I know, they're discontinued now. So any finding is gonna be pricy.
Than you all for your inputs. This thread will be good for others if they need a replacement.
Oh no, a specific model of an industry-standard component is discontinued...
I found some parts on Mouser, but not an identical one.
True, Mouser don't seem to have a drop-in replacement in stock, but whaddya know...
https://www.digikey.com/en/products/detail/bourns-inc/PEC11L-4225F-S0015/4699180
Also happens to be the cheapest fitting one they carry 🤷‍♂️ Not that Bourns is a no-name in the field anyway.
