micaddict
Hey Jim, good to "see" you.
Thanks for chiming in.
Henk
Henk
chunger said:UPDATE:
Prototypes are finished. . . but, we have a typhoon that has stopped transportation. More information after the Typhoon clears. My associate in China will send pictures ASAP and we will see where we are at.
StaticRick said:chunger said:UPDATE:
Chunger, any updates on the GT-2B and SYT-5 bodies?
chunger said:Due to late returns, I have the following available. . . please email me [email protected] if interested
1x SYT-5 body kit new condition
1x B-stock SYT-5 body kit (small dent in tube near base. . . almost unnoticeable when assembled)
Several people have expressed interest in one of these, and I have directed all parties to monitor this thread for the latest developments on the gen.2 bodies so i thought it fair to post here.
poctop said:chunger said:Due to late returns, I have the following available. . . please email me [email protected] if interested
I will take it or i know somebody that will take it , consider it as sold,
DAn,
poctop said:poctop said:chunger said:Due to late returns, I have the following available. . . please email me [email protected] if interested
DAn,
I will only take te SYT-5 thanks , i guess you can have the GT-2B if you wish ,
DAn,
jandoste said:Hey Chunger,
I received my package but without PCBs :'(
please tell me did you send them or we got a mistake here?
chunger said:Hi jandoste,
I have no way to cross-reference your groupdiy member id to your order. Please send me an email with the contact name you used for your order and I can check. Either I made an error and forgot to pack the pcb or the pcb was not ordered (it is a separate item in the webstore).
Chunger, would you mind addressing these questions? I don't think they've gotten answered yet, but maybe I missed it. Thanks!Melodeath00 said:chunger said:UPDATE:
We are now on revision 1.2 of the C12 pcb set. Only the slightest of changes was implemented on the revision. The board was lengthened by .060" to give slightly more length to the output capacitor slot. The V-cap 250V 1uF OIMP type capacitor now fits without mods. Since the kit-supplied Erse units have been working superbly in stock .56uF and 1uF options, I have not had a chance to test these super-expensive caps that are likely more snake-oil than actual "sonic gold" in our application. There was discussion about extending the PCB length all the way down to the base of the mic to facilitate easier mounting of the AMI or Cinemag transformer, but recent tests of the clone against vintage original early type C12 leave the question open about whether the larger core early-style transformer may be a better performing setup overall. Inquiries to Oliver at AMI about possible development of such a reproduction transformer have gone unanswered so far, but I can try Cinemag and other capable transformer specialists to see. Anyways, the short story is I would like to leave enough space at the bottom of the mic for the larger core transformer should that ever become available.
There was also discussion about printing a dedicated ELA M251 board, but after some thought, Matador figured the changes necessary to the build are trivial enough that we really don't need a new board. . . as originally stated. . . even though he did lay out a board. So, we will most likely proceed with a detailed build guide on the current PCB for the ELA preamp circuit. Note: 9 position pattern switching of the C12 will be retained in our build so this will be a hybrid setup. Sonically, in theory, it should not make a difference how the capsule is polarized. Benefits are obviously more pattern options, easier build as we retain OEM physical configuration, and the ability to use capsules that do not have isolated backplates (most available options do not have this!).
Prototypes of the 2nd Generation GT-2B and SYT-5 bodies are moving forward. The latest word is that the factory has completed "some" samples for me. I presume this is at least the final revision SYT-5 prototype but could very well be both SYT-5 and GT-2B prototypes along with 2nd revision HT-11A headbaskets to incorporate a slight bend in the hoop base for cleaner lines (as originally spec'd but not executed correctly by the first-run factory). I am again, cautiously optimistic. A few photos will confirm if we are on-track or stalled again. There is a Chinese holiday until the 7th (that would be today) so I would think I should hear something around the 10th. Stay tuned here for updates.
New products are in the pipeline:
1. "prototyping" pcb set for the HT-11A microphone. This board is similar to the C12 PCB set but has no traces except for the tube heater supply voltage. Teflon standoffs in press-fit configuration at the top of the mic will allow for traditional turret-board style wiring of C12, ELA M251, or any number of other mic configurations desired. For those who would like to experiment with a point-to-point type tube mic build, this is a clean platform to do so in the HT-11A body with minimal fabrication and fitting of parts.
2. Fully regulated psu board. . . most build problems we have encountered revolve around the passive B+ voltage supply of the current psu design. The fully regulated design will allow for larger range of voltage adjustment and easier build. With Matador's attention to the technical details, I am confident this will be clean and noise-free option. We will of course test it head to head against the existing passive B+ type psu to confirm that it runs without issue. Wider adjustment range should allow this psu to be used for more microphone types without adjusting passive components.
3. Switch mode power supply adjunct pcb for U87 AI type circuit to use in conjunction with poctop's DU87 PCB's.
Can you elaborate on the big core transformer? It sounds like you're saying the larger core original C12 sounded better. What was better? Bigger bass?
HT-11A revision - will this include a dampened headbasket to get rid of ring? You said cautiously optimistic, but since I am still waiting on my CT12, I could stand to wait for the revision headbasket, possibly.
C12 point-to-point board - Any timeframe at all, or potential price?
Will it still be possible to get the older C12 PSU board? I just want the closest to original c12 as possible.
does this mean prototypes or sale-able units?My factory rep has let me know they will try to get product in my hands in December.
teacat said:thanks for the update,does this mean prototypes or sale-able units?My factory rep has let me know they will try to get product in my hands in December.
