Various boards (LA2A, SSL4k pre, 4 rail PSU, High voltage PSU)
HoneyBadger Audio
Active member
Croatia
Hello Everyone!
I posted these about a month back and people really seemed to like the builds. A little back story, I started making DIY units about 7-8 years back. mostly the usual suspects, LA2A, 1176, STA level SSL EQ... fast forward and i started to manufacture my own PCB's of these projects. I have for sale the PCB's for these projects, which include all the necessary documentation, BOM wiring... you know, all the stuff you need to build a unit. I have some info, pics and demo's of some of these units on my website.
For all those in Europe,I am located in Zagreb Croatia and shipping within the EU is pretty cheap, flat rate up to 1kg for 9.5 EUR. For everyone else it's 15 EUR to the rest of the world.
DISCLAIMER: I'm posting it here since I have't heard back from any moderator regarding a merchant account. If there is a moderator that sees this please reach out and I would be happy to comply with whatever needs to be done. :)
LA2A board: 40 EUR
description: 1:1 1968 audio path with Lundahl in/out TX and T4B octal socket.
High voltage PSU: 20 EUR
description: a regulated power supply for most tube applications. Includes 3 voltage rails, 1x 6.3v heater, 1x variable high voltage rail, 1x aux rail for relays, lights...
SSL4k pre: 15 EUR
description: the compact SSL pre with high ratio Lundahl input TX and THAT output IC. Probably the easiest build, only about 40 components.
Quad rail PSU: 22 EUR
description: 4 variable rails to power almost any project. 1x 48v phantom power, 2x positive rails (3-30v), 1x negative rail (3-30v) with LED indicators and fused outputs.
1176-D: 24 EUR
description: A compact 1176 limiter PCB. this model has the reduction switch assembly on the main board for easy wiring. Comes with the Cinemag input TX board and a stereo link board.
PRE-ORDER: Items will be shipped out in the fall of 2022
DUAL EQP-1A: 75 EUR
description: A dual mono version of the super popular EQP-1A. this is a 1:1 of the original Pultec design and includes footprints for Greyhill switches or sockets for wiring up your own (alpha, Lorlin...), SOWTER transformers, large film capacitors, PC tube sockets and much more.
for more details check out the website: DIY audio parts and supplies – HoneyBadger Audio
Thanks GROUPDIY!
    109.4 KB
    187.6 KB
    117.1 KB
    194.3 KB
