dmp
Are you going to use a submin tube socket on the m269, or solder in the tube? A socket would be preferable I think, but I don't know if they are available other than vintage & rare.
dmp said:Are you going to use a submin tube socket on the m269, or solder in the tube? A socket would be preferable I think, but I don't know if they are available other than vintage & rare.
the submini have wire lead , the M269 will have turrets installed on the socket pcb to easily swap tubes out
Dan,
dmp said:the submini have wire lead , the M269 will have turrets installed on the socket pcb to easily swap tubes out
Dan,
Excellent idea!
Is this the plan for the m49 as well?
kjdemarest123 said:I'll take a set of the Large D-U87 PCBs, thanks!
poctop said:My hosting Server wich is dropbox has issue at the moment so no order can be processed , ( Ayo i am tired of technologies )
it should be up running in a short while,
Dan,
bkbirge said:49c pcb set paid for. Not sure why I keep adding pcb's to my backlog. It's a sickness.
Addiction always have a cure... but it's so painfullpoctop said:bkbirge said:49c pcb set paid for. Not sure why I keep adding pcb's to my backlog. It's a sickness.
OK Got it , Thanks , will ship soon, they are still working on the Cure
Dan,
