- Joined
- Apr 10, 2016
- Messages
- 82
As long as the heat from the tube doesn’t weaken the adhesive and there’s room enough inside the tube, anything that increases the damping should improve the resonance.A couple years back i bought a sheet (A5-sized or so) of some adhesive-backed rubber, maybe 2mm thick or so, for the purpose of damping mic body tubes. Haven't yet gotten around to actually using it yet, but that might be a cheap-ish option?
That video is really sobering…it is enough to make you want to machine a new body tube than try to fix the old one. I can’t imagine using those faux 67s on something like piano, which is how Keith Jarrett’s “The Köln Concert” was recorded. A notch filter might not be enough.
